Which cold air intake to buy??
I have a 96' Formula & the next thing on my list is a cold air intake. I've been looking at SLP's kit which is $200, K&N which I believe is also $200, and Moroso which is $190. Does anyone know which kit is supposevly the best? I would think SLP would be good but I dont like the fact that it has 2 air filters. Any input is appreciated.
Just my opinion, but I've had bad luck with my K&N FIPK. The filter has fallen off on me once or twice. Personally, I would have thought they would have designed a bead on the filter end of the tube to help keep the filter from falling off accidently. I don't know if any of the other kits have a potential problem like this but figured I'd give my 2cents
Get a K&N.It can be upgraded With a filter change to go along with future engine mod's.Tubing size will support about 1500CFM.The 6" cone filter flows about 700CFM.If you want to stop the filter from coming off,build an 2 part epoxy riser(bead) in 4 spots around tubing below where clamp goes(around bottom of tube).Slide filter past raised portions and tighten clamp.
Originally posted by Darren P
what is the prob with a G2
I like the stock look.....
http://www.lgmotorsports.com/OCLT1_Fbody_Induction.htm
I didnt like the design of the K&N or the Moroso cause I have to drive my car in the rain and we get alot of road flooding here in Indiana so I bought a Jet elbow that is supposed to use the stock filter box and bought an angled K&N fillter and poked about half of it threw the hole where the K&N or moroso would do to get good cool air but its not so close to the road. Mine seems to work pretty good. I ran my car with the filter and without and barrowed an FIPK set up and never gained or lost any MPH or E/T. Hope this gives you some more ideas. Oh yeah! I only have about $65-70 bucks in the whole thing.
Jeremy
Jeremy
Moroso or K&N
