Cold Air Intake for a '95 Z
Looking for a little help on the many Cold Air Intake systems out there. My Z is stock w/6 speed. The K&N seems to be the "standard" but do any of the cheaper "tube" systems work as well?
Re: Cold Air Intake for a '95 Z
I went with the RK Sport SS Ram Air Hood on my 94 Z-28 works great and comes with k&n air filter and elbow to hook right up to you mass air sensor...now thats a little bit more expensive then a cold air intake but works awesome and look even better
I bought an intake for a Honda Civic, 3 inch aluminum, Cut 3 inches off of the straight end, shoved the other end in into the factory plastic part that is on the corner of the radiator. Then installed a Spectre Cone filter in the fender just like a K&N Setup. According to Datamaster, I'm flowing as good as any of the expensive aftermarket setups and I have like 75 Dollars in it. I did this years ago though, part could be more now.
94z28jbw
Sep 8, 2002 03:22 PM
ezcheeze15
Aug 26, 2002 01:28 PM
slothgrant
Aug 22, 2002 03:01 PM
