cold air intake
Old Jan 13, 2008 | 10:29 PM
97'Z-28's Avatar
cold air intake
I found this CAI on Ebay and just wanted to see if anybody has one and what they think of it. it is 3in. diameter tubing, do you think thats big enough? I will be using a K&N filter with it. TIA!
http://cgi.ebay.com/ebaymotors/1994-...spagenameZWDVW
Old Jan 13, 2008 | 11:22 PM
Fatdog2's Avatar
Well it sure looks real nice,but remember the steel will pick up a lot of heat,where the plastic will run cooler.I like the coldest air possible.Anybody else want to chime in?
Old Jan 14, 2008 | 12:18 AM
LearJet's Avatar
You get what you pay for.....If your looking for performance I would get something that works. That looks like 5$ worth of cheap tubing and some hose clamps.
Old Jan 14, 2008 | 09:58 AM
97'Z-28's Avatar
I'm on a preaty tight budget these days,thats why i considered that CAI. would the aluminum tubing really make the air hot enough to make a difference? my K&N CAI puts the filter right behind the headlights,so my engine is getting hot air, right? what other cai would you guys recomend. thanks for the help!
Old Jan 14, 2008 | 10:01 AM
bombebomb's Avatar
Most recommend anything but ebay CAI, you can buy cai new from around 160-200 for a quality one.
Old Feb 23, 2008 | 08:48 PM
euforia51's Avatar
There's probably nothing wrong with that CAI; outside of the metal tube which does carry heat. The 3" diameter tube is fine. Anything bigger would be a waste because it will get reduced once it reaches the MAF.
I had a home-made CAI out of 3" plastic flat-corrugated tubing with a good sized K&N on it that worked great. Maybe a tad ghetto with the rubber fittings I was using, but it worked well.
Later, I thought the 'right' thing to do would be to get an SLP CAI (also metal tubing) ... and I really don't like it. It will be for sale before long. If the one on e-Bay is all you can afford at the moment, go for it.
Old Feb 24, 2008 | 03:10 AM
Counted Out's Avatar
It will work fine, but I've heard of people having problems fitting it.
If you're already going to buy a filter look around here and other Camaro forums (LS1 Tech is a good one) and look for someone selling a used one.
I got a Moroso one for $75 with a filter.
Someone else was going to sell me a Moroso for $40 without a filter. Infact, if anyone wants that guys email, I'm pretty sure he still has it.
Old Feb 24, 2008 | 08:46 AM
AHARTZ28's Avatar
i just got an LPE for $140 shipped from http://www.lingenfelter.com/store/ln0041.html
i would never go with one of those ebay intakes
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
ezcheeze15
Aug 26, 2002 01:28 PM
slothgrant
Aug 22, 2002 03:01 PM
