Coil and Map sensor questions .....
Old Jul 23, 2005 | 10:29 PM
BigJustinZ28's Avatar
what are some symptoms of a bad MAP sensor ???
also the terminal on my coil broke off when I unclipped the plug on it and I want to replace it. Should I go with a factory one or the MSD OEM Replacement one (I looked up the blaster and it said oem replacement) ?
Old Jul 24, 2005 | 01:29 AM
HBHRacing's Avatar
Re: Coil and Map sensor questions .....
Faulty map can do several things but will generaly set a code when there is a problem. You can test it with a multi meter and a vacuum pump and watch for the volatge range to change as you apply vacuum.
For the coil. What "termonal" broke off?
Old Jul 24, 2005 | 12:57 PM
the harness one . lol , I made this post last night after a 14hour trip to pick up a friends car lol , i was a lil tired lol. I already ordered a new coil. Went with AC Delco.
HectorM52
Jul 30, 2017 11:46 AM
Fatdog2
Feb 13, 2015 08:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
HCz28
Jan 11, 2015 11:17 AM
AlaskaZ28
Dec 10, 2014 02:37 PM
