Coil difference?
Old Nov 24, 2008 | 10:09 AM
David94TA's Avatar
Coil difference?
I was on Golen's website reading their tech tips for LT1/LT4 engines and they recommend using the stock coil from 96-97. Is there a difference in these years vs. earlier?
Old Nov 24, 2008 | 10:38 AM
bombebomb's Avatar
Yes, I read about it on here somewhere. But the simple anwser is yes.
Old Nov 24, 2008 | 11:12 AM
The 96-97 coil is a one connector coil and is a little more potent than the stock 94-95 dual connector coil. You could always get an aftermarket dual connector coil and be in the same ballpark without having to worry about any wiring/connector changes.
Old Dec 1, 2008 | 11:18 AM
David94TA's Avatar
OK, thanks for the replies.
Old Dec 1, 2008 | 12:59 PM
marshall93z's Avatar
I've had an MSD coil leave me on the side of the road before.
Old Dec 1, 2008 | 01:38 PM
seawolf06's Avatar
I had the same problem with an MSD coil. They're all made the same way, so I'm not sure what happened. I have a Crane now and it's worked for 3 years strong.
Old Dec 1, 2008 | 01:50 PM
bombebomb's Avatar
I had a stock one on my 89 rs fail like 5 times. I think we had an electrical issue however. It would kill my ignition module and the coil at the same time, everytime.
Old Dec 1, 2008 | 03:07 PM
Green96Z's Avatar
Mine has been working for 3 years. Of course my whole ignition system is MSD, not sure if it makes a difference.
Sergio
Jan 27, 2016 04:27 PM
ad356
Apr 22, 2015 08:35 PM
greenzee28
Mar 26, 2015 09:13 AM
