Codes 36 and 42
Old May 10, 2010 | 10:16 PM
madhatter's Avatar
Codes 36 and 42
Started up the new motor this weekend. Had an instant SES light on. Car isn't tuned yet for this setup, but was tuned for last setup(355/ported heads/cc305). We used the old opti, wasn't having any problems before. Little help?
95 Z28
385
Ported stock heads and intake 2.02/1.60
58 mm TB
42lb SVOs
Lunati 60123
Sean
Old May 11, 2010 | 05:14 AM
Guest47904's Avatar
Guest
36 is inconsequential at this point. Concentrate on the 42 which is the IC signal on the white wire between the ICM and black PCM connector pin 5. First thing to check is the number 11 fuse 10amp UH. If that's good, measure voltage on the pink/black wire and the white/black wire at the ICM with KOEO. Be sure the black wire at the ICM is grounded properly.
Then get to the opti feedback signal after you take care of the 42
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
