code scanners
code scanners
Hello everyone I just found this site and need some help. I have a 94 z28 and want to be able to read the codes from the computer. I had a code scanner that is just a jumper type and it will not work even though the book said it would. I am not sure if I have and obd I or II, everything I read says it is an obd I which should work with my jumper type reader. Can someone tell me what will work to read the codes without spending a fortune.
This is the one im looking at getting and its for OBD1, or OBD2, so you could use it on any other cars you have. I also only heard good things about it from people that have them.
Where do you live in SC? I live in Blythewood. http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
