Code 43 and broken valve springs?
Old Apr 7, 2005 | 01:46 AM
Kurt Crosbie's Avatar
I got a code 43 on my 95 LT1. Said something about an electric spark control module or sensor or something.
I ended up taking the valve covers off and finding 2 broken valve springs.
#1 Could the messed up escm cause a broken valve spring?
#2 Could the broken valve springs cause a code 43?
Old Apr 7, 2005 | 09:50 AM
Re: Code 43 and broken valve springs?
If you used the code list on Shoebox's page:
http://shbox.com/1/Dtcs.htm
....rather than a "generic" list, you would have found:
DTC 43 = Knock Sensor (KS) circuit
You have a faulty knock sensor or wiring to the knock sensor. Or maybe the racket and rattle of the broken springs overloaded the sensor and left it unstable, but that's a "reach". The sensor is very easy to check with a multi-meter.
Old Apr 7, 2005 | 12:57 PM
Z95m6's Avatar
Are you running 1.6 RR's with that 847 cam? if so you are pushing those 987's to the limit probably why you broke them.
Old Apr 7, 2005 | 06:50 PM
I was running the cc305 with comp springs (not sure what kind, but they looked close to stock) and some kind of comp lifters.
I will be running the 847cam with 987 springs and stock lifters.
Old Apr 7, 2005 | 07:11 PM
Z95m6's Avatar
If you plan on running 1.6's with that setup you are really gonna be pushing the 987's in my opinion.
Old Apr 7, 2005 | 08:43 PM
MaxLean's Avatar
You didn't notice two broken valve springs until you pulled the covers? Man it must have been running awefull!
Red_94Formula
Jan 22, 2015 12:17 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
