Code 42 and car acting very odd.
Old Oct 9, 2004 | 05:11 PM
Ryan94ZA4's Avatar
the car has been running funny lately but it had not been throwing any codes at all. Today, it threw a code 42 (IST Grounded) but this may have just been a fluke as it did it when the car was cranking.
Car usually starts then immediately dies. You try to start and it does this a few times. If you give it a little gas, it will start and miss badly. If you leave it running, about half the time, the car will smooth out. Once you have the car started and it's running, it runs fine the whole time for that run cycle.
Any ideas??
Old Oct 9, 2004 | 06:19 PM
chrism400's Avatar
Re: Code 42 and car acting very odd.
Is your fuel pressure ok? Fuel filter?
Old Oct 9, 2004 | 06:26 PM
Ryan94ZA4's Avatar
Pressure seems fine. Brand new Walbro 255 pump and a newer filter...
Old Oct 9, 2004 | 11:22 PM
apick42's Avatar
had the same problem three days ago the icm was going out
good luck
Old Oct 9, 2004 | 11:31 PM
chrism400's Avatar
Well, if it is the icm, that's easy enough to get tested. Autozone.
Old Oct 9, 2004 | 11:46 PM
Ryan94ZA4's Avatar
I have already tried a different ICM and had a new coil laying around and plugged it in. Neither fixed the problem. I have good fuel, good coil, good ICM, good PCM. Only other thing I can think of is the opti is coming apart inside or just going out. Is this feasible?
Ryan
Old Oct 10, 2004 | 12:13 AM
apick42's Avatar
go to shoeboxes web site and you can find out how to test the opti
Old Oct 10, 2004 | 09:38 AM
Ryan94ZA4's Avatar
That tells how to test the optical portion, not the cap and rotor section. I am thinking that the cap and rotor is trashed at this point.
Ryan
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
