code 42
Old Apr 29, 2004 | 03:52 PM
Max 93's Avatar
code 42
42 Ignition Control (IC) circuit (shorted or grounded circuit). Any help on this one.
Old Apr 29, 2004 | 04:45 PM
GreenDemon's Avatar
My Hayne's manual- quote: Check the wiring and connections between the ignition module and the ECM/PCM. Replace the ignition module. *Replace the ECM/PCM*
*- Component replacement may not cure the problem in all cases. For this reason, you may want to seek professional advice before purchasing.
ICM or connections...
Old May 9, 2004 | 04:21 PM
Max 93's Avatar
I have tried a differant PCM and ign. control mod. Can't find anything wrong with the wires. Any other ideas?
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
