Code 33 Map sensor high
Old Aug 28, 2009 | 02:42 PM
SmokeyBlaZe's Avatar
So it threw this code the other day and I know that on the green connector that go's to the map sensor the clip is broken but it still seems like it is getting a tight/good connection, Would I likely have to replace the sensor itself or just the connector? I called a local autozone and they have 2 in stock with a 90 day warranty for 35 dollars but they are the store brand which is Duralast? should I go ahead and replace the sensor with the AZ brand or order an acdelco and spend at least twice the money and have to wait for 3-5 days? I would also have to order the pigtail/connector because the stores don't carry it /can't get it. Any input is appreciated.
Old Aug 28, 2009 | 04:42 PM
If you have a broken clip, I don't know why you would be replacing the sensor first. Replace the pigtail. Eficonnections or lsxtune has reasonably priced pig tails.
Old Aug 28, 2009 | 10:15 PM
Efi connections is down til sept 1, 2009 but lsxtune has it for 5.99
http://www.lsxtune.com/shop/product_...roducts_id/459 So I'm gonna change out the connector reset the pcm and pray for no cel.
Old Aug 28, 2009 | 10:17 PM
Should I just crimp the wires and tape them?
Old Aug 28, 2009 | 10:59 PM
Solder and heatshrink is the way I like to do it.
Old Aug 30, 2009 | 03:11 PM
still waiting on my pigtail to arrive, Took off the sensor and the hole was clogged with oil so I cleaned it all up. The little seal is warped so I put some teflon tape under it and tried to stretch it back out for a quick fix, now the car is missing mostly at lower rpms but I can turn the car off and back on and the miss is totally gone but it comes back pretty soon.Any input is appreciated. thanks for the reply
HectorM52
Jul 30, 2017 11:46 AM
Fatdog2
Feb 13, 2015 08:19 PM
Amshnock
14
Jan 18, 2015 11:47 AM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
