Code 29 - Secondary Air Injection (AIR) Pump Circuit
Old Jun 1, 2006 | 02:12 PM
KyleBlue85Iroc-Z's Avatar
It's blowing the AIR fuse under the hood. If I just pull the relay for the pump will everything be ok? I looked at the wires going into the pump and they look fine, and when I replace the fuse the pump runs, but then blows after driving for a while.
Old Jun 1, 2006 | 02:37 PM
anaik's Avatar
Re: Code 29 - Secondary Air Injection (AIR) Pump Circuit
Just unplug the pump.
Old Jun 1, 2006 | 02:42 PM
onetransam4u2nv's Avatar
put a higher amp fuse it will be fine
Old Jun 1, 2006 | 03:08 PM
If you want to disable the pump, just unplug it's electrical connector and make sure there is a good fuse in the fusebox. Normally, the computer will not complain if you do it this way.
Old Jun 1, 2006 | 03:30 PM
Trying this method right now.
Old Jun 15, 2006 | 10:25 AM
michigan2500hd's Avatar
Just wondering if this worked for you. Mine is running right after start up and is loud, also it keeps kicking on and off.
Old Jun 15, 2006 | 11:57 AM
Yeah, I just replaced the fuse, cleared the code and unplugged the connector on the pump. Since then it's been fine. Now I'm wondering if my car is running worse because it thinks the pump is working?
But to answer your question, yes, the method worked!
Old Jun 15, 2006 | 02:30 PM
Your car isn't "running worse because it thinks the pump is working". The AIR pump only runs for a couple minutes at start up, to burn excess fuel in the exhaust and help the cat(s) heat up faster. After that it shuts down. Has no affect in any way on the way the engine runs.
95 and newer LT1's are covered by a "recall" on the AIR pump, in the event you would like to keep it working.
Old Jun 15, 2006 | 07:28 PM
Mtrhds94Z's Avatar
That recall # is 99083
Old Jun 16, 2006 | 05:36 PM
They still honor recalls on my car?
Old Jun 17, 2006 | 03:18 PM
Recalls are driven by emissions requirements, repairs of which may extend well beyond the normal warranty period for the rest of the car.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
