code 26 & 28 HELP PLEASE
Old Nov 5, 2007 | 08:31 AM
redington's Avatar
Code 26- EVAP purge control solenoid circuit. EVAP solenoid circuit indicated as faulty. Check wiring and connections.
Code 28- Transmission Range (1994-95). Check the transmission control range circuit for any opens or shorts. Verify transmission range pressure switch is working. Range "A" is on ecm pin "C28" to terminal "N" on transmission plug in, Range "B" is on ecm pin "C29" to terminal "R", Range "C" is on ecm pin "C30" to terminal "P".
Thats what i found on the net. I have a 93 so i dont know about code 28 i posted. Does anyone know 28? What do they mean? After i got the codes checked the car ran at 500 rpm on idle. Any help would be awsome. Mods are in sig
_ mike
Old Nov 5, 2007 | 09:48 AM
Go to Shoebox's LT1 code list, and look at the far right-hand column for the 93 codes.
http://shbox.com/1/Dtcs.htm
DTC 26:
Quad-Driver Module (QDM) #1 circuit
applies to:
- AIR pump relay circuit
- EGR solenoid
- EVAP solenoid
DTC 28:
Quad-Driver Module (QDM) #3 circuit
applies to:
- fan control relays
- a/c relay
Why did you have to "get the codes checked"? You can flash them on the SES light using a paper clip on the ALDL connector..... see instructions on Shoebox's website:
http://shbox.com/1/dlc2.jpg
Old Nov 6, 2007 | 02:14 PM
redington's Avatar
it was free and easy to stop by a shop and have it done. I dont have AIR or EGR so how would i trouble shoot these codes?
Old Nov 6, 2007 | 05:29 PM
If you have deleted the EGR solenoid and/or removed the AIR pump without having a good fuse in the circuit, it will cause DTC 26.
Are your fans working correctly, or do you have an add-on fan switch? That could cause DTC 28. Also could be a problem with the A/C relay.
Old Nov 11, 2007 | 11:18 PM
redington's Avatar
how would i test the ac realy? Would this cause the lights to flicker if it was the relay?
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
