code 16 and 36 Optispark
Old Sep 21, 2005 | 08:04 PM
79TTCAMARO's Avatar
Im getting a code 16 and 36 . It basically says that im loosing a signal to my distributer. While driving....my car just cuts out....I wait a couple minutes and sometimes it will start and sometimes it just trys, but dies right away. I have no warning its going to happen it just dies. Is this a common problem with the optispark? I thought the cap and rotor usually go bad. Can you replace just the pickup in the opti? It is less then a year old. I replaced the coil with an msd one I had laying around just to see if it would help, and it did nothing.
Old Sep 21, 2005 | 11:26 PM
Re: code 16 and 36 Optispark
Replacing the coil wouldn't help, since the computer is telling you it's opti related. Maybe your opti harness has corrosion.
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
Russtebo
Aug 31, 2002 08:53 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
