Coating Valve Covers to reduce valvetrain noise/false knock
Old Apr 5, 2007 | 03:21 PM
  #16
WS Sick's Avatar
Originally Posted by 1LESSZ28
Yep. I guess I have to do some research lol. I had been told by the dealer that the lt4 used different valve covers due to 1.6 rr but I guess that isn't correct after all.
Its allways nice to see a guy that can admit he's wrong..lol
But yeah the noise is because the parts are connected to the block not from reverberation off the covers etc.
Old Apr 5, 2007 | 05:23 PM
  #17
Um that's incorrect. the LT4 used 1.6 rollers that the lt1 vette did not which caused false knock which is why there is the LT4 knock module and LT4 composite covers. do some research.
Also the fact that the sensor is in the block doesn't mean it doesn't register outside interference such as exhaust.
The LT4 had a different knock module, with a filter specifically to filter out the Crane Gold roller rock noise. The noise is transmitted through the metal of the block at a much stronger rate that off the surface of the valve covers, through the air and around to the bottom of the engine, through the iron block and the coolant to the little piezo microphone in the knock sensor. I'd rate that as a non-issue.
The covers would be somewhat effective in minimizing noise emitted outside the engine, including to the passenger compartment. That may well have been the deciding issue.
The 92 Corvette LT1 valve covers were magnesium. In 93 they were replaced with plastic. Ref:
Magnesium is expected to roll up lots of new applications in the '90s, but it recently lost a round to a thermoset plastic on the '93 model Corvette. American Cyanamid Co. of Wayne, NJ, replaced the light-weight the cast metal on the valve covers of Corvette's 5.7L LT-1 engine with its Cyglas high-performance thermoset material.
Doing a bit of research is always a good idea.
HectorM52
Jul 30, 2017 11:46 AM
karnykamaro
Feb 2, 2015 01:37 PM
HectorM52
Jan 30, 2015 11:34 PM
ModdedNerd
Jan 29, 2015 07:23 PM
thenewkid
Nov 29, 2014 04:54 PM
