Clutch Question
Old Apr 28, 2003 | 08:32 AM
OffspringZ28's Avatar
Clutch Question
What makes the clutch "springy". what makes the pedal come back up after you release it? Throwout bearing? Master/slave?
Old Apr 28, 2003 | 02:59 PM
JohnD's Avatar
Nope. The force originates in the clutch diaphragm spring. When you let off the pedal, it pushes everything back-via hydraulics from the slave cylinder back.
Old Apr 28, 2003 | 10:42 PM
is it possible to break these hydraulics? ever since the clutch 'club' security device pulled the pedal back too far it just feels like mush now.
Old May 7, 2003 | 08:21 PM
TTT
Old May 8, 2003 | 08:38 AM
any clutch experts in here? i want my clutch to be springy like it used to be...
Old May 8, 2003 | 09:30 AM
95 Z/28 LT1's Avatar
Super Moderator
You might have ruined your master cylinder by pulling it back further than it is supposed to go.
Old May 15, 2003 | 12:20 PM
Sam95ZNoTop's Avatar
If your fluid was low, you could have sucked air in the system, that would make it springy. If this is the case, add more fluid and bleed the system.
Sam
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
BPS
9
Mar 5, 2015 10:51 PM
Newgmman
Feb 25, 2015 02:53 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
