Clutch problems!!!!! Help fast.
Old Jun 19, 2003 | 08:19 PM
White98Z's Avatar
THe other day made a 500 mile trip in a 93 z28 6speed. THe problem is when the clutch is all the way in it makes some noises about like a light metal to metal sound. The car does not want to go in to gear it is like the clutch is not adjusted correct. When you take it and drive it the clutch holds fine like it is not sliping or anything. What could it be i was thanking it was the slave cylinder or the master not pushing it in all the way.
Old Jun 19, 2003 | 08:28 PM
duckhead4life's Avatar
maybe you should check your clutch master cylinder fluid. and then bleed the system too. and if that doesnt work . the only thing i can think of to tell you is that you are going to have to take everything apart.(like you would if replacing a clutch) inspecting and replacing as you go because that could be a number of things.
Old Jun 19, 2003 | 08:36 PM
White98Z's Avatar
THe fluid id full stop checked it when it started acting up.
Old Jun 19, 2003 | 08:39 PM
have you tried bleeding your system man. you might have an air bubble in there or something. that not letting you clutch do its job.
Old Jun 19, 2003 | 08:51 PM
Z95m6's Avatar
the first thing that comes to mind when you say noise while the pedal is in is the throwout bearing.
Old Jun 19, 2003 | 08:54 PM
White98Z's Avatar
Yea the noise does sound like a throw out bearing but it should still go in to gear.
Old Jun 19, 2003 | 08:56 PM
like i said before man and i really hate to say it. but you will never know until you take it apart and see.
Old Jun 19, 2003 | 08:58 PM
White98Z's Avatar
Yea i know tha is what i am hateing this is a friends car he just drove from bartlesville oklahoma to houston tx and we are at a new house no tools and no jack so we are kind of up the creek.
Old Jun 19, 2003 | 09:12 PM
well if it doesnt seem to be getting any worse. i would just drive it as little as possible until you get the resourses to figure out the problem. good luck man.
Old Jun 19, 2003 | 10:05 PM
Brad91B4C's Avatar
If its a loud almost like a growling noise its same thing I have been having and Sean @ MMT told me it is most likely throwout bearing. It doesnt do it all the time on mine.
Brad
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
