Clutch pedal softer now
Old May 2, 2003 | 10:49 AM
fbird95's Avatar
My clutch pedal used to be a real task to stomp down. I got a new clutch and now the pedal is relitivly soft. Not like mushy but like a standard clutch you would find in most cars. Any problem with this.
Old May 5, 2003 | 12:09 AM
fbird95's Avatar
Nobody knows.
Old May 5, 2003 | 12:14 AM
IgorT.455/406's Avatar
It should not be really soft, but if your clutch was very, very worn, then everythings sounds ok. What kind of new clutch? How does it drive?
Old May 5, 2003 | 12:54 AM
fbird95's Avatar
I got the new one and its softer than the old one. Sorry for the confusion. the old clutch was reals stiff, the new one soft. Although the new one is more along the lines of a stock set up.
Old May 5, 2003 | 01:15 AM
camaro6's Avatar
Thats because your old one was an aftermarket clutch. Your new one is basically stock. I guess aftermarket clutches are stiffer than stock.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
