Clutch disk question
Old Jun 15, 2003 | 09:00 AM
Bilmind's Avatar
I have a friend with a spare clutch disk from his 2000 SS, and was wondering if that disk would work with my 94 Z28?
Thanks...
Old Jun 15, 2003 | 07:50 PM
Bilmind's Avatar
No one knows?
Old Jun 16, 2003 | 12:52 AM
fbird95's Avatar
As far as i know it should word with out a problem.
Old Jun 16, 2003 | 07:50 AM
firepheasent's Avatar
No it will not work..... Check out the part #s for discs only at any given perfromance store.
Later,
Jason Coffman
Old Jun 16, 2003 | 08:06 AM
PatriotTA's Avatar
It won't work. LT1 and LS1 are two different engines, with two different set-ups.
Old Jun 16, 2003 | 02:15 PM
fbird95's Avatar
PatriotTA its a good thing you caught my error, sometimes late at night when i am half asleep certain things slip my mind. Like the fact of 93-97 LT1 and 98+ LS1.
Old Jun 16, 2003 | 02:19 PM
Bilmind's Avatar
Well I know they're different engines and different hydraulics, thats why I was wondering if the disk would be useable or not because they are the same tranny with the same input shaft, but I guess the disk diameter is different?
Old Jun 16, 2003 | 02:28 PM
unTAmedLS1's Avatar
Also I believe the pp and flywheel are different. I think that the disc size on our LT1 cars are the same as most sb chevys while the flywheel and disc on an ls1 car are larger and also our cars are externally balanced while the ls1 I believe is internally which is why are flywheels are different too. Not sure if that is perfectly accurate though
BPS
9
Mar 5, 2015 10:51 PM
cmyname1
Feb 19, 2015 08:38 PM
HectorM52
Jan 30, 2015 11:08 PM
Noer
Parts Wanted
Jan 19, 2015 10:19 AM
rockync7
Jan 1, 2015 05:10 AM
