Clunk from rear of the car
Every time i get the car inspected i get something busted or stollen no matter where i go. Anyway i got the car inspected yesterday and now everynow and a again i hear this clunk noise from the rear of the car. It sounds like when you fill an empty gas tank. Its not real loud and you cant feel it in the car. I think it might just be the driveshaft, Any Ideas> Thanks
Remove the spare tire and see if that fixes it. If not I'd try checking the panhard rod bushings, I had a problem where the 93 in the sig. would have a weird rear end rattle/vibration, I replaced them with poly bushings and that problem went away
I checked out the panhard bushings and they look to be ok. One of my freinds told me that the car may be pissed off with how they took it off the lift. Today the car is not making the noise, i also made sure the spare was securely fastened, because i had a problem with this rattling a few times before. I think the temperature may have something to do with it because today its over 40 degrees. Thanks for the help
Dec 4, 2014 11:56 AM
owen66
Nov 30, 2014 04:21 PM
squarehead
Nov 21, 2014 08:02 PM
