Cluctch Pedal is not comming Back
Old Aug 15, 2014 | 04:58 PM
Mir Hussain's Avatar
Question Clutch Pedal is not comming Back
Hi there,
I have notice lot of things has change in this forum.
If my posting is in Wrong forum please move it to correct forum
I have notice my clutch is pedal is not coming back; so I am having
a hard time changing a gears.
What would cause that ?
I did notice clutch fluid is like Dark Brown!
I dunno I can change it or not I should haved!
Please assist
car is in the Sigs
Old Aug 16, 2014 | 01:16 PM
DocJhn's Avatar
Re: Cluctch Pedal is not comming Back
I would give the clutch cable a look see.
Old Aug 16, 2014 | 02:11 PM
JakeRobb's Avatar
Super Moderator
Bleed the clutch until you have all new fluid in there. It's tricky to get all of the air out. I just did a new clutch and slave cylinder last month, and I still have some air in the system.
Old Aug 16, 2014 | 04:10 PM
No cable.... clutch activation is totally hydraulic, with a unique "pullback" design, as opposed to the conventional "pusher" design.
Old Aug 16, 2014 | 04:45 PM
Chimera96's Avatar
OP
I don't know if F-body pedal has a return spring as mine (doesn't have one) is a custom pedal in another application using the LT1 "pull" type clutch
otherwise sounds like a hydraulic issue be it MC or slave. You can buy a complete sealed MC/slave for around $125
Old Aug 16, 2014 | 11:29 PM
I have it fluid swap......... but no go............
so it is probability Mc/Slave issue
Originally Posted by Chimera96
OP
so it is a standard price every where ?
Thanks fellows
Old Aug 17, 2014 | 09:22 AM
You have to shop around for a complete/assembled MC/braided SS line/Slave. Search using the GM part # (if anyone knows it) or "LT1 clutch hydraulic assembly". I found prices ranging from $US 145-225. Like virtually anything you buy, the price varies, and of course being in Canada, you have to convert to $Can.
Old Aug 17, 2014 | 12:23 PM
Chimera96's Avatar
rockauto.com has the ac delco 12559912 for $120...also have SACH & LUK. My bet is they are all EXACTLY the same made unit.
Old Aug 17, 2014 | 01:52 PM
Thumbs up Re: Cluctch Pedal is not comming Back
You are awesome!
I was to get for $185 CDN shipped to me.
Item turn out to be this
That is for whole kit; I dunno its a good idea to buy whole kit; or just do the experiment and change master cylinder first then slave ?
or change the whole thing.
Does any body have a write up or just a know how to do it ?
I mean I have take the trany out to do the slave cylinder ?
Thanks in Advance
Mir
Old Aug 17, 2014 | 02:21 PM
Chimera96's Avatar
while your MC "or" slave may be the problem, the LT1 hydraulics are not set up to easily bleed so buying the pre-bleed whole unit, IMHO, will make the repair easier
I don't have a F-body as my car is another application using the LT1 system but it appears you just un-clip the pin holding the MC to the pedal pin, remove the 2 nuts from firewall side, remove the 2 nuts from slave holding it to bell housing, remove 2 screws holding reservoir on and assume there is a hold down nut on the braided line and pull the unit as a whole. Install in reverse
a service book like a Haynes manual should also have a step by step.
FYI, leave the plastic strap on when you install the slave, it will break 1st time you push the clutch. DO NOT push clutch pedal without slave being installed...or you will explode the slave
Old Aug 17, 2014 | 04:14 PM
Question Re: Cluctch Pedal is not comming Back
Where I can get those........ I looked around nobody selling that!
Old Aug 17, 2014 | 05:41 PM
rngilliland's Avatar
MC is the master cylinder. It is inside the car and hooked to the brake pedal. The slave is bolted to the bell housing. The part you said you ordered includes the MC and slave. It comes assembled, filled with fluid, and ready to install. Post #10 tells you everything you need to know about installing it.
Old Aug 17, 2014 | 05:42 PM
Chimera96's Avatar
if you are asking about a service manual, try amazon.com or ebay
Haynes makes them for just about every car. usually around $25
Old Aug 17, 2014 | 08:53 PM
Many many moons ago I bought the service Manual for Fbody I think for 96-97 I have to check
I am sure it would have the producer ?
Aging guys all of you really helping me and I do appreciate a lot
Old Aug 18, 2014 | 02:08 AM
Lightbulb Re: Cluctch Pedal is not comming Back
I have not check the services manual yet.
Do I need to remove trany to get to slave cylinder ?
or I can do with 2 bolts (I think ) ???
I know for master I have two bolts at the firewall (inside) and clip at pedal clutch side.
Then reservoir handing inside the hood by Brake booster.
