Cloyes Timing Set
Old Apr 2, 2003 | 04:48 PM
Jesse_Boyer's Avatar
Cloyes Timing Set
I need the part number for the Cloyes Double Roller timing set that everyone uses. The one that is 79.00 bux or so.
Also, does that come with gears as well, or is it just the chain?
Also again, can I use a 94 timing cover with that setup? I've already got a CSI pump that i'm currently using
Old Apr 2, 2003 | 10:18 PM
Grease's Avatar
The part number will vary depending on where you buy it from but the last 4 digits usually are 3145
If you buy it from Summit racing it CLO-9-3145, from Jegs its 220-9-3145 from Doug Herbert its 9-3145.
The chain comes with both crank and cam gears.
Old Apr 2, 2003 | 10:38 PM
Hence the term "set".
Old Apr 3, 2003 | 06:29 AM
limige's Avatar
cool but do you have to change the cover on a 94?
i'm in the same boat and would like to know....
what's the part #'s on the electic water pumps? how much do they run?
Old Apr 3, 2003 | 06:43 AM
QUASARBLUEZ28's Avatar
You need the 95 timing cover to use the cloyes set on a 94 I am fairly sure . I went the whole way and converted to the vented opti when I did mine.
HectorM52
Jul 30, 2017 11:46 AM
Jan 23, 2015 01:13 PM
chuyz28
Jan 15, 2015 04:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
