Closed Loop. Replaced numerous sensors. No success.
Old Aug 8, 2011 | 11:19 AM
djm_e22's Avatar
This is a newly rebuilt engine. That I have yet to work right. Car runs great when I am in open loop or when I have the O2 sensors disconnected. As soon as it goes into closed loop I can't accelerate worth crap. Even though I have no codes showing these certain sensors bad I went ahead and replaced numerous ones.
Replaced
1. Both O2 sensors
2. Maf sensor and Pigtail
3. ECT-Engine Coolant Temperature sensor in water pump
Maybe I have an exhaust leak, but wouldn't I show a code for a lean condition in one of the banks???
Maybe I have a vacuum leak. I checked vacuum and it is at 11-12 or so. But I also have a fairly big cam.
Any thoughts? Thanks.
Old Aug 8, 2011 | 01:36 PM
AkiraHunter's Avatar
Re: Closed Loop. Replaced numerous sensors. No success.
Are you able to get a scan tool with live data on it? Check to make sure your O2s are doing what they should on closed loop. Possible you could have exhaust/vac leaks, but won't always check a code. Also, being this is a new engine, is it tuned for all your mods? Any backfiring?
Old Aug 8, 2011 | 04:06 PM
calaban's Avatar
Are any of the wires for your O2's burned between the ECU to the connector.
Get a datalog, it should tell you if your sensors are working correctly.
Good Luck
Old Aug 8, 2011 | 05:17 PM
ray396's Avatar
Cool Re: Closed Loop. Replaced numerous sensors. No success.
Hi, What about a Tune, MAF cal. could be off?
Old Aug 8, 2011 | 05:30 PM
djm_e22's Avatar
The engine has been tuned(mail). Had two different people tune it thinking the first one may have mistuned it. But came up with the same issue on both tunes. I have a aeraforce gauge that scans the pcm while the car is running. It shows both MAF and O2 sensors reading.
Keenan
Jan 19, 2023 12:24 PM
maybe2fast
Mar 16, 2015 11:59 AM
silvermansteve
Mar 4, 2015 05:02 PM
armedtrigger
Feb 24, 2015 08:30 PM
NewsBot
Feb 6, 2015 05:00 PM
