Clogged Cat? you tell me
Clogged CAT will result in a progressive loss of power as rpm's increase.
If it is really bad, it will barely rev to 2000rpm.
Easy way to check is to remove the air injection tube frome the driver side exhaust maniold. This will temporarily open up the exhaust. If the car runs significantly better, then the CAT is plugged, or a pipe is crushed.
what about if it blows a bunch of carbon out at high RPMs, it did that to me the other day and hesitated it at WOT it does fine til about 4500 rpm then it just craps out kinda it loses power all of a sudden. maybe its the cat hopefully thats all it is
Another way to tell if the CAT is plugged is by using a vaccuum gage. They are relatively cheap, and are great for engine diagnostics.
Attach a vaccuum gagae to the intake manifold, and not the reading at idle (should be 18-22"). Next hold the rpm at 2000, and take another reading (should still be high, maybe even 24"). repeat for 3000, 4000, 5000 rpm.
If the readings get progressively lower as rpm increeases, something is plugged.
Mine was so bad it only had 16" at idle, and droped to 12" at 2000rpm. Engine would die at 2500rpm.
I unplugged one of the air injection tubes, and readings immediatley went back to normal.
Don't worry too much about what kind of CAT to replace with, just make sure the inlet and outlet of the CAT has a generous taper, and has the right size inlet/outlet diameter. You''ll notice that the stock CAT has a fairly lousy inlet/outlet design. Almost anything is an improvement over stock.
Originally posted by cz28s
what brand of aftermarket cat should i get that is good?
They are VERY overpriced and not worth the insignificant gains. Your best bet is to ditch the cat. and replace it with an off-road pipe. Hold on to the cat. until it's emissions time.
Sep 11, 2015 09:44 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
