CLO-C-3039 Timing Chain Set... Anyone else running one??
Old Oct 19, 2007 | 01:02 AM
hotrod18_69's Avatar
CLO-C-3039
Cloyes Heavy Duty Timing Set
I've got one in my new motor.. I did a search and didn't come up with anything on it..
I happen to find it at autozone first then found it on summit.. Just looking for alittle background if anyone has run one.. It looks just like the LT4 ED, but its a non-roller..
I fired the motor up last night, everything sounded great.. Soo far.. After reading about the ED water pump drive issues, i am alittle worried.. Due to there similarities.
Old Oct 19, 2007 | 01:58 AM
SS RRR's Avatar
No proven facts that the ED "water pump issues" were the fault of the ED cam gear.
Old Oct 19, 2007 | 02:36 AM
Well this is true.. But its still has be a bit worried...
Old Oct 19, 2007 | 06:52 AM
Then, why didn't you use something else?
Old Oct 19, 2007 | 09:19 AM
I thought i would take a chance. I don't regret not buying it.. I just have the thought in the back of my head..
I'm just looking to see if anyone else is running this same set up, or if i am the ONLY one out there soo far..
Old Oct 19, 2007 | 10:15 AM
krillformula's Avatar
I´m putting one in my car soon..
Old Oct 19, 2007 | 12:10 PM
1racerdude's Avatar
As long as the oil holes are in the front plugs for the gear ya won't have a problem.
Cloys makes them for GM so it is probably the same.
Old Oct 19, 2007 | 01:49 PM
quickSS's Avatar
Notice that is a stock LT1 timing set
That's a good timing set. It is the Cloyes aftermarket version of the stock GM timing set. The only bummer on using it is you won't have crank sprocket timing adjustment for exact cam phasing but that is the only bummer. I love the stock timing set up. Quiet and strong.
Karl
Old Oct 20, 2007 | 11:55 AM
jclark311's Avatar
I am using that set, the machine shop used on offset key for the cam timing, dont have the motor in yet, but i agree, its just like the stock set, and should hold up well.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
