clearity about the opti
Old Jun 25, 2007 | 04:46 PM
ZL1modified's Avatar
does the opti have anything to do with fuel coming out of the injectors?
anything at all... ex. via a code thru the pcm...
Old Jun 25, 2007 | 04:59 PM
If the computer sees no pulses from the opti, the injectors will not operate.
Old Jun 25, 2007 | 05:01 PM
thanks, now is there anyway to trouble shoot the possibility...
Old Jun 25, 2007 | 06:25 PM
MeanGreen97Z's Avatar
Check for the opti pulse on the harness.
Old Jun 25, 2007 | 06:46 PM
how
Old Jun 25, 2007 | 06:49 PM
ricehammer's Avatar
Use this procedure
http://shbox.com/1/4th_gen_tech2.html#opti_test
Old Jun 25, 2007 | 07:13 PM
wrd1972's Avatar
The opti low res pulse syncs up the fuel injectors.
To test the low res pulse turn the key to the run position an turn the crank over by the balancer hub bolt. You can do this with a breaker bar and socket.
As you manually turn the crank you should hear the injectors momentarily kick on in a similar fashion that they do when you turn the key from the off position to the run position.
Also if the low res fails you should get a code, I think 16 but I might be wrong.
Old Jun 25, 2007 | 07:31 PM
i did scan the pcm for codes and came up with nothing...
would this rule out the optispark?
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
