Clearance with my LT's and a 1.75 drop...
Old Dec 10, 2003 | 06:58 PM
crAzy95z28's Avatar
just as the title says....
can this work, i jsut got hooker LT's and a 1.75 drop/springs
how close will this bee? also i will be getting a custom made y pipe...
randy
Old Dec 10, 2003 | 07:50 PM
crAzy95z28's Avatar
tttttttttt
Old Dec 10, 2003 | 07:53 PM
NJCustoms's Avatar
It's going to be very tight. If you live in the North East were the roads are ****, you'll have problems
Old Dec 10, 2003 | 08:04 PM
crAzy95z28's Avatar
live in Tx, houston....
only thing i have to worry about is going over the railroad tracks and speed bumps huh?
Old Dec 10, 2003 | 08:08 PM
96LT14u2Nv's Avatar
dont know man. i put front v6 springs on my car and it sits about 1" lower in the front and my LT's rub on EVERYTHING!!!!! im not saying it cant be done without problems, but i would think u are going to be rubbing quite a bit
Old Dec 10, 2003 | 08:39 PM
All4Chevy's Avatar
Would there be any problems if it rubs every now and then? as long as you dont bounce up in the air and come down and land on them shouldnt they be fine, with some scratches?
Bill
Old Dec 10, 2003 | 08:47 PM
crAzy95z28's Avatar
i was prob going to put them on the rear to drop the rear down..cause it looks liek my car sits higher int eh backk....
but will itbe ok?
randy
Old Dec 10, 2003 | 08:49 PM
696redZ-28's Avatar
mine in lowered aprox 1.5 inches with long tube jet hots avoid speed bumps at any cost! i've rubbed mine on some humped driveways no real damage. My car is not a daily driver but easly could be here in Florida. my clearance a smidge over 3 inches.
Old Dec 10, 2003 | 08:51 PM
96lt1Camaro's Avatar
ITS NOT WORTH DROPPING YOUR CAR. You put in lts because youre more likely like the 1/4 mile. So get some drag launch springs from Ebiach. Awesome for the strip and can still hold turns on the street!!
Old Dec 10, 2003 | 09:00 PM
crAzy95z28's Avatar
damn........i already bought the sprigns though....
and its a daily driver....
how close to the curb will i be...
i mean look at vipers/ferraris/mclarens/and other badass car..
look how low they are on the ground...
randy
Old Dec 10, 2003 | 09:30 PM
kyzer soze's Avatar
I got jet hot lt's hooker y-pipe and dms springs. I cant go over speed bumps if both tires have to go over them. I can go over a speed bump if only the two right tires go over. I hope that made sense. I scrape everytime its not worth it . If you can't avoid speed bumps good luck. Im going back to stock springs too many speed bumps in my area
Old Dec 10, 2003 | 09:34 PM
crAzy95z28's Avatar
what was your drop? 2? or 1.75? or 1.5? or 1?
Old Dec 10, 2003 | 09:38 PM
dnz28's Avatar
I live in houston and had to take my 2inch drop off. you are going to get owned by speed bumps, any pitches in the road so and you will have to become a master like i to pull into a parking lot with out riping your bumper cover off.
Old Dec 10, 2003 | 09:42 PM
crAzy95z28's Avatar
well usually when i go up steep curbs or driveways, i go in at a angle...
Old Dec 10, 2003 | 09:45 PM
revtime's Avatar
All those sports cars you mentioned were designed low to the ground and the exhaust was designed to fit without ground clearance problems.
3rd and 4th gen Camaros were not designed to run true dual exhaust, it can be done obviously but not without compromise.
I have Hooker LTs and purple horny header mufflers and I have a Drag Launch kit which raised the rear of the car up.
I still scrape the mufflers on speed bumps and high spots in the road sometimes get me.
After driving my car with the current setup there is absolutely no way I would run LT headers on a lowered Fbody.
Some guys do it but I don,t think my exhaust would last long.
