Cleaning the Throttle Body
Old Apr 17, 2005 | 08:56 PM
  #16
OBE1 95Z28's Avatar
Re: Cleaning the Throttle Body
Yes the rod goes through the butterflies and rotates...this is the area to lube.
Old Apr 18, 2005 | 12:26 AM
  #17
I've seen "cautions" NOT to use "carb" cleaner on a throttle body, because is will remove the coating put on the blades to help them shed carbon buildup. That's why they make "throttle body" cleaner. I honestly dont know whether the LT1 TB blades have these coatings.
Sorry to hijack but is there any reason that the tb plates have gaskets? I was wondering last time, do they need to seal anything?
What plate gaskets are you talking about. The bottom plate on the TB contains the IAC passages and the coolant (assuming its still connected). I leak of either air or coolant into the IAC passages will screw things up badly. The top plate covers the chamber that connects the valve cover air supply hose to a port that starts in front of the throttle blades. A leak at that point would pull dirty air into the intake. Why would you NOT expect to find gaskets?
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Fatdog2
Feb 13, 2015 08:19 PM
lt1-xjs
Jan 17, 2015 07:52 PM
