cleaning o2 sensors
Old Aug 25, 2007 | 11:35 AM
pizzi-man's Avatar
cleaning o2 sensors
Is there a way to clean the o2 sensors?
Old Aug 25, 2007 | 11:58 AM
Fuels94TA's Avatar
What I use is a brench grinder with the wire wheel. It will clean all those deposit off. If you don't have one, a wire brush will work but you won't get those hard cake on areas of deposits off.
Vinny
Old Aug 25, 2007 | 01:02 PM
What you can see of the sensor is just the metal shield, protecting the zirconium membrane inside. Other than cleaning the carbon off the shield, there's not much you can effectively do to clean the actual sensor. I've seen people claim they did it with brake cleaner or something similar, but its hard to see how any sort of solvent would be good for what is a fairly sensitive membrane.
Old Aug 25, 2007 | 01:13 PM
C Man's Avatar
I've also heard that you can rotate the O2 sensor 1/2 a turn to get the "cleaner" side facing towards the exhaust. I've never done it, but it's worth a shot.
Old Aug 25, 2007 | 02:54 PM
pizzi-man's Avatar
test
Old Aug 25, 2007 | 02:56 PM
pizzi-man's Avatar
Thanks for the replys. I was under the impression that the outer shield was impregnated with something special that made the sensor work.
Old Aug 25, 2007 | 04:40 PM
mrmint69's Avatar
If you have a scanner and the O2's are working i would not mess with them. If they go bad then i would definately replace since they are so important to a good running car. I got them for $40 each for Factory AC Delco so it makes the investment cheap and gives you piece of mind.
Fatdog2
Feb 13, 2015 08:19 PM
Jazsun
Dec 29, 2014 12:14 PM
