Cleaning the MAF...
Old Jun 30, 2004 | 06:28 PM
Myxtreme1's Avatar
Cleaning the MAF...
Im taking my MAF housing to work tomorrow to polish it and found the little "bars" that have the resistors are very dirty. Could this be causing any problems and how do I clean them without effecting the resistors? Also does removing the bar in the middle of the housing help air flow or does it hurt? I have heard it does good and I have heard it can hurt it. Someone bring some clarity here. Thanks!
Old Jun 30, 2004 | 06:30 PM
Myxtreme1's Avatar
P.S.
Yes it is apart. I'm not going to polish it with it all together .
Old Jun 30, 2004 | 08:19 PM
Fuels94TA's Avatar
Yes you can clean them but be very careful and take your time. Dont use rags, you might snag one of the wires and break the resistor. What I did was use a cotton swab and spary carb clearner on the swab tip and clean up the areas in the maf.
Vinny
Old Jun 30, 2004 | 09:08 PM
Myxtreme1's Avatar
Do you think it being dirty can cause any probs?
Old Jun 30, 2004 | 09:11 PM
Dave89IROC's Avatar
YES
Old Jun 30, 2004 | 11:59 PM
Muskys SS's Avatar
Don't use carb cleaner on it!!! I've heard that you can damage the sensors. I was told to use a cotton swab and windex
Old Jul 1, 2004 | 01:37 AM
Lt1t56's Avatar
Be carefull. I used Radio Shack Precision Electronics Cleaner and a cotton swab, worked great for me. The Radio Shack cleaner is like $10.00.
Old Jul 1, 2004 | 05:53 AM
Eliminator's Avatar
I used cotton swab and rubbing alcohol.
Old Jul 1, 2004 | 03:03 PM
O-taka's Avatar
Q-tip and isopropyl here also
i bent one of the wires, they are very fragile
Old Jul 1, 2004 | 03:26 PM
Black94mula's Avatar
Yea I would never touch it. Just get some electric parts cleaner and spray it real good. I just did that to mine about a week ago, runs fine.
Old Jul 1, 2004 | 06:03 PM
Myxtreme1's Avatar
So did you notice a difference?
Old Jul 1, 2004 | 07:42 PM
tanmanski's Avatar
a buddy of mine couldnt pass emmissions, had SES lts intermittantly, codes pointed to MAF sensor, pulled it out, it was filthy. Turns out he over-oiled his re-usable air filter & oil mist/vapor got all over the MAF sensor. YES, a dirty MAF sensor will definitley cause you problems. As everyone said, just be really carefull about cleaning it. Aerosol electrical cleaner or isopropyl alcohol seem to work best & are proven.
p.s GM also has a tech service notice out that contaminated MAF sensors are likely caused by aftermarket air filters being over-oiled & that it is NOT a warranty covered item...
Old Jul 1, 2004 | 08:30 PM
Dave89IROC's Avatar
so if you have a k&n, put a paper one in when you go to the dealer, and don't put the k&n sticker on
Old Jul 1, 2004 | 09:31 PM
tanmanski's Avatar
Geez Dave ya sound like an old pro at that game...oh wait, I see you ARE a pro! I'm with ya tho, GM's had their way with me often enuff...
Jeff1904
Jun 5, 2016 05:00 PM
marlar98
Sep 19, 2015 07:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
