Cleaned my TB and MAF
Old Aug 22, 2003 | 04:13 AM
  #16
revtime's Avatar
I did this recently and it made a huge difference.
I have 135k on my motor so I replaced the TPS and IAC after I cleaned the TB real good.
Took me about 1 1/2 hours to complete but I was not hurrying.
I finally did the coolant bypass as well, only took me 5 years.
Old Aug 22, 2003 | 08:56 AM
  #17
stereomandan's Avatar
Is there anything to watch out for when removing the cables or wires? Any of them easy to break, or hard to get off? Sounds like a good project this weekend.
I cleaned my MAF last week and couldn't believe the difference. I can't imagine it running any smoother than it is now, but I'll clean the TB since it's never been done.
I have TB cleaner. Is that o.k., or is Seafoam the only one to use.
Here's my post about the way I cleaned the MAF. I actually used a Q-tip to carefully wipe the sensors clean.
http://www.camaross.com/forums/showt...hreadid=159448
Dan
Old Aug 22, 2003 | 09:13 AM
  #18
95BlackTA's Avatar
Carb and choke cleaner works perfectly fine. The throttle cables are easy, just take a look and you will see how they are on there. ONe just slides right off, and the other has a lil cylinder doodad attached to the cable, just slide it right off...too hard to explain, you wont have a problem when you look at it. AN extra pair of hands is always nice when trying to put it back on though.
95blkss
Parts Wanted
Jul 19, 2015 08:42 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Noct
Jul 14, 2015 01:18 AM
