Ckeck your antifreeze !
Old Jan 24, 2004 | 10:21 AM
NOMAD's Avatar
Exclamation Ckeck your antifreeze !
I went to start the Camaro yesterday in the 9 degree weather. I started it up and went inside to get Allison and Heather. When I came back out the car was slowly dying
I managed to get in about the time she died on me. Everything looked fine, but when I cranked it back over nothing happened, no spark or anything
I check everything over and finally found that the water pump fuse had blown. I plugged a new fuse and pulled the cap to make sure the water pump was flowing. When I pulled off the cap I found nothing but a slushy mess. All of my coolant had frozen The water pump was frozen solid inside.
Just a reminder. Keep an eye on that coolant. Mine had been in there for a year or so, and was a cheapo autozone brand. FWIW, my van wasn't frozen. using Peak anti freeze... lol
-Shannon
Old Jan 24, 2004 | 10:29 AM
lt1g3n's Avatar
damn, that sucks!... I guess i'll be sticking to peak
Old Jan 24, 2004 | 10:31 AM
blazzinbird's Avatar
I just changed mine out, but man that really sucks, slush isnt ever good
Old Jan 24, 2004 | 10:35 AM
Hyperspeed97z28's Avatar
to much water in that stuff, always good to double/triple check that stuff...
Old Jan 24, 2004 | 10:38 AM
joeSS97's Avatar
Hope you didnt damage your engine.
Old Jan 24, 2004 | 10:45 AM
NOMAD's Avatar
I dunno, I always use a 75/25 mix with more 75% anti freeze. I used a 50/50 mix in my van with no probs
I think maybe the anti freeze has just broken down and the glychol isn't doing it's job, or the fact it was cheap $4.99 Autozone brand.
Good news is that my opti just got a lil damp but no damage, running good today now that it's up to a whopping 30 degrees
-Shannon
Old Jan 24, 2004 | 11:26 AM
94_Z28_guy's Avatar
How well do those cheap anti-freeze testers work?
Old Jan 24, 2004 | 03:47 PM
anaik's Avatar
Another good reason to use NPG, no H2O in it. I own stock in the company by the way .
Old Jan 24, 2004 | 04:06 PM
SlickBlack Z's Avatar
Speaking of antifreeze...does anyone know why the "red stuff" gums up and clogs the heater core? I flushed my heater core thouroughly last year and now its clogged again....what's the deal?
Old Jan 24, 2004 | 05:09 PM
anaik's Avatar
Here's an article on the subject.
http://www.imcool.com/articles/antif...l-macs2001.htm
Old Jan 24, 2004 | 05:34 PM
Ok...so DEX-COOL sucks...but what's a practical solution? Are there potentially other areas of my motor that are clogging up like the heater core? I dont like this.
Old Jan 24, 2004 | 05:48 PM
anaik's Avatar
You could flush your cooling system really well and go to the green. I say really well, because the two mixing is also bad.
Old Jan 26, 2004 | 08:58 AM
LWillmann's Avatar
That article you posted says nothing about it being "bad"
It says, "Mixing a “green” coolant with DEX-COOL reduces the batch’s change interval to 2 years or 30,000 miles, but will otherwise cause no damage to the engine. In order to change back to DEX-COOL however, the cooling system must first be thoroughly drained and flushed."
Which tells me that it won't last as long as a pure Dex-Cool / Water mixture, but it won't cause engine damage either.
Old Jan 26, 2004 | 05:38 PM
sskilla9three's Avatar
were you using pure antifreeze...or was it a 50/50 mix...j/w
Pwilson59
Sep 3, 2015 08:47 PM
pimpen1024
Aug 19, 2015 08:36 PM
warmeck
Mar 1, 2015 08:47 PM
GM98Z
Nov 28, 2003 07:33 AM
rumair
Sep 18, 2003 05:12 PM
