Chrome Moly STB?
Old Jun 22, 2003 | 12:34 PM
All4Chevy's Avatar
Chrome Moly STB?
I was reading about the shock tower brace on BMR's website and it says:
Standard model is made with strong 1/4" mounting plates and 1.25" x .095" tubing while the chrome moly version is 1.25" x .065" tubing to insure zero deflection under load.
Am I missing something? How can the 'chrome moly version' be stronger and thinner at the same time? Shouldn't the .095" one be stronger than .065"??
Thanks,
Bill
Old Jun 22, 2003 | 12:53 PM
Bud M's Avatar
The chromemoly brace is probably roughly equal in strength but lighter. Chromemoly is stiffer than mild steel. The standard BMR brace seems pretty stiff to me. When I try to flex mine by pulling on it I can't detect any flex.
Old Jun 23, 2003 | 07:35 AM
The advantage of chrome moly is its ability to provide the same strength with only 2/3 as much material. It saves weight.
The weight saving on a chrome moly roll cage is appreciable.... about 35# over carbon steel. On an STB, its probably a saving of 1.0 - 1.5#. You have to decide if that's worth $30.
Old Jun 23, 2003 | 09:11 PM
bruecksteve's Avatar
I have a BMR STB but I can't compare it to anything. I just went with Chrome moly because it was lighter. I don't need to add anymore weight than I have to.
Henson071
Dec 30, 2015 09:55 PM
Catmaigne
Jul 14, 2015 05:17 PM
CARiD
Jul 7, 2015 08:19 AM
1963SS
Feb 6, 2015 10:05 AM
