chrome moly pushrods get scarred up from guideplates?
Old Oct 3, 2004 | 04:07 PM
97s10ondubs's Avatar
Im getting the LE2 setup done, the heads have been sent out, im looking now for all the supporting parts, the car will have guide plates and i was looking at chrome moly pushrods but read that guide plates will scratch the chrome moly pushrods and cause them to fail. The site said that case hardened is what you need to use. I this true? Also what would be a good case hardened set to get, I'm really going overkill on the top end cause I dont want anything to break.
Old Oct 3, 2004 | 04:10 PM
Spinner's Avatar
Re: chrome moly pushrods get scarred up from guideplates?
Chromoly pushrods should be much harder then standard hardened pushrods.
Old Oct 3, 2004 | 04:13 PM
SStrokerAce's Avatar
A good pushrod like a Hi Tech Comp pushrod is case hardened. BTW a guideplate should also be hardened too. That's why you don't grind away on guideplates to make them fit. That will go thru the case hardening and eat away at either the PR or the guideplate.
So make sure you get some Bowtie guideplates and some good Hi Tech pushrods.
Bret
Old Oct 3, 2004 | 05:27 PM
^ ok where do i get them from
Old Oct 9, 2004 | 10:25 PM
91l98z28's Avatar
Will grinding anywhere on a guideplate damage them?
I have comp hi-tech pushrods and isky adjustable guideplates (i had to get adjustables for my application), and a few had to be ground on...one or two to clear the washer on my arp head studs... no grinding near the pushrod slot, though.
Bret
Old Oct 9, 2004 | 11:15 PM
Spinner's Avatar
Only near where they rub would it hurt. The hardening is a surface coat, once you grind past it, it isnt there. As long as its not around the slot, its ok
13qtr
Oct 28, 2016 08:11 PM
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Catmaigne
Jul 14, 2015 05:17 PM
CARiD
Jul 7, 2015 08:19 AM
