Chrip First To Second
Old Jul 8, 2003 | 12:16 PM
95 WHITE TRANS's Avatar
When you chrip the tires from first to second on a A4 dose it cause any damage to the tranny.
THANKS
NICK
Old Jul 9, 2003 | 01:08 AM
fbird95's Avatar
In the long run, yeah, just like barkin them with a M6, the clutch doesnt show signs of going out right away.
Old Jul 9, 2003 | 01:16 AM
95DropTopZ28's Avatar
It's better for the friction material part of the clutches because they don't slip which causes wear and heat but it puts more strain on the backing plate/metal part of clutch. Thats what blew out on my 4l60e in my blazer.
Old Jul 9, 2003 | 06:36 AM
revtime's Avatar
I had a Trans Go shift kit in mine and it hit 1st to 2nd HARD.
I put the shift kit in at about 50k and the tranny went south at about 125k. I ran it hard but did not abuse it so I don,t think I can complain.
From what I have been told having the tranny shift harder is better for it, less slip.
Old Jul 9, 2003 | 07:23 AM
Bastardcat's Avatar
I don't know the mechanics involved, but for what it's worth, I asked Brian at PCMForLess if having firmer shifts was harder on the tranny and he told me it was actually better for the tranny. Now I don't know if you just have stock programming and are chirping from 1st to 2nd--but my PCM is programmed for firmer shifts and I typically will get a little chirp from 1st to 2nd whereas before I did not. I am a conservative driver for the most part so I am assuming that my small chirp is not causing any problems. On a side note, I think that if you're gunning it and purposely chirpping the tires it's probably going to cause some problems later on.
Old Jul 9, 2003 | 03:35 PM
I installed the hypertech programmer it will chrip only when i bring
up the rpm,otherwise it will give me a nice firm shift.I really felt a diffrence with the programmer. Much better than the gm performance button.
THANKS
NICK
Old Jul 9, 2003 | 08:34 PM
Snoochies's Avatar
I know for a fact that intentionally chirping the tires will fry the clutches in your trans. Actually my trans broke last week because of this reason. I'll say that the sole reason my trans broke was because I was ALWAYS chirping it into 2nd. Normally I wouldn't floor it and let it chirp on its own. I liked to punch it till about 35 mph, then let off the gas, and then nailed it and I'd get some crazy barking into 2nd. I definitely admit that I singlehandedly killed my trans. My car only has 60k miles on it. But I'm not complaining, this just gives me a reason to beef up my trans and throw in a stall converter.
Old Jul 10, 2003 | 12:10 AM
fbird95's Avatar
If harder shifts were better for the trans what Snoochies wrote wouldnt have happened.
Chirping or spinning the tires, especially while moving is not good on the trans.
Old Jul 10, 2003 | 12:12 AM
revtime's Avatar
You guys are no fun.
Second gear scratch is one of the reasons to live.
Old Jul 10, 2003 | 12:23 AM
IrocManiac's Avatar
I've always heard spinning the tires is hard on the trans, but I don't understand it...how is it hard on an auto and an M6?
Old Jul 10, 2003 | 06:53 AM
Bastardcat's Avatar
I agree with this--but I think there's a difference between harder shifts and firmer shifts. Getting your vehicle programmed for firmer shifts is not the same as gunning it and letting it kick into the next gear hard.
briand069
May 20, 2010 01:26 PM
rpepka
37
Mar 31, 2010 11:34 AM
narlydude
Apr 29, 2006 09:56 AM
WhiteSSAllen
Feb 8, 2006 05:51 PM
95 WHITE TRANS
Jun 16, 2004 07:37 PM
