checking timing?
Old Jan 5, 2011 | 09:38 AM
jklopez09's Avatar
checking timing?
it might be a dumb question but can you check the timing with a timing light on a 93 z28 and if so whats the best way? i haven't ever used a timing light, but i just bought one and hopefully it works on this car. i think my timing chain might be off a little after cam swap. thanks in advance for your help
Old Jan 5, 2011 | 09:45 AM
Re: checking timing?
All timing is done by the computer and not traditionally checked with a timing light. Give some more info about your symptoms and maybe that will lead to some suggestions.
Old Jan 5, 2011 | 10:15 AM
jklopez09's Avatar
the headers glow after running it for a while and every so often it will pop from the intake. other than that the engine runs fine
Old Jan 5, 2011 | 12:41 PM
RamAir95TA's Avatar
Glowing headers could mean a significantly lean condition (or you have super thin headers ) or a clogged cat (if you have it). I would get a scanner on it and have your tuned looked at.
Old Jan 5, 2011 | 01:26 PM
jklopez09's Avatar
i got pacesetter headers, no cat, and the tune was done by madz28. how could i make sure it was running lean?
Old Jan 5, 2011 | 01:30 PM
RamAir95TA's Avatar
A wideband would be able to tell you.
Old Jan 5, 2011 | 02:49 PM
jklopez09's Avatar
i dont have a wideband. i will see if the tuner will look over his tune for me. thanks
jb4xx
Feb 2, 2015 10:00 PM
squarehead
Jan 15, 2015 07:02 PM
Collector Car
Jan 5, 2015 10:58 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
danielbmx
Aug 27, 2002 11:11 PM
