Checking pushrod length..where to get a single solid lifter?
Old May 6, 2007 | 09:16 PM
2QUIK6's Avatar
It makes sense to measure for your required pushrod length using a solid lifter, alot of the instructions I've read do not mention that, but one or two did since you want to check for the max lift travel while checking the geometery as you do not know just how much a hydraulic lifter will collaspe at high rpms...
So with that said....where can you buy just 1 solid roller lifter?? All I can find are entire sets and I sure don't need to buy a whole set of 16.
Old May 6, 2007 | 09:19 PM
wrd1972's Avatar
Get a hydro lifter, take it apart and shim it up so it wont collapse. You can easily do this with one of your good 16. I have even used a very light spring from the hardware store if the lifter is holding oil while turning the oil pump with a drill.
Old May 6, 2007 | 10:21 PM
cehan's Avatar
Yeah, do like WRD1972 says. You need to use the same kind of lifter that you're going to run in the engine to make sure the pushrod cup depth and all the other dimensions are the same.
Old May 7, 2007 | 03:58 AM
sssalah's Avatar
Yes, I just use the checking spring that came with the degree wheel kit
Old May 7, 2007 | 10:05 AM
Dave88LX's Avatar
Local machine shop should have plenty of junk lifters to play with.
Old May 7, 2007 | 10:24 AM
2QUIK6's Avatar
Thanks for the info, I'll try the shimming idea with the old lifters that came out of it originally.
Old May 7, 2007 | 11:40 AM
cehan's Avatar
Just be sure that the old ones are the same as whatever new ones you are going to use. When I replaced the stock GM lifters with CC 850-16's, I found that there was quite a difference in the depth of the pushrod cups between the two.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
