checkin EGR Valve..gettin to it???
Old Jul 29, 2004 | 05:21 AM
1Qwik94Z's Avatar
Red face checkin EGR Valve..gettin to it???
What is the best way to get to the EGR Valve due to its location on the rear of the intake? Im having hesitation/stumbles at slight/heavy acceleration..there is a considerable amount of power loss. I read a couple books on HOW TO replace but none of them mention how to actually GET TO it..the easiest way..
There is a gasket on it as well...and since the location is REALLY crappy..whats the best way to pull it off..check it..and ensure the old gasket is removed before installing the new one? Thanks guys, Derek
Old Jul 29, 2004 | 09:51 AM
Re: checkin EGR Valve..gettin to it???
The best way to get to it is probably not the easiest way. It is easier to reach when the flexible fuel lines are removed from the manifold and the EGR solenoid is also removed. A mirror can also help if you are going to remove it, so you can see what's back there.
Old Jul 29, 2004 | 01:04 PM
Dave C. '97 Z28's Avatar
It easy, just remove the engine and use a 13mm socket!
Or, you can do as Shoebox suggested if you don't have the extra couple days to take the motor out....
-Dave C. '97 Z28
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
