Check engine light
Old May 19, 2014 | 12:35 AM
Jake500g's Avatar
Check engine light
Got it scanned a while back. Egr solenoid is what it came up with.
When I start up my car it gets warmed up then light comes on. When I come to a complete stop at a stop light it will go off and then as soon as I start to go it comes back on. What should I do? How should I go about replacing it.
1994z28 camaro
Old May 19, 2014 | 05:23 AM
bw_hunter's Avatar
Re: Check engine light
The egr unit is mounted on the back of the intake manifold and is held on by two nuts....1/2" open end wrench will get it off. Before replacing it, check the vacuum line to it to make sure there isn't and cracks.
Now that I think about it, I'm not sure a 94 will give an EGR specific code. Can you post the the actual code?
Old May 19, 2014 | 11:00 AM
OBD-1 94 has two codes for the EGR:
DTC 27 - EGR Vacuum solenoid circuit fault
DTC 32 - EGR flow
http://shbox.com/1/egr1.jpg
Old May 19, 2014 | 04:18 PM
bw_hunter's Avatar
Thanks, Fred....sorry for the misleading post.
Old May 20, 2014 | 05:26 AM
Check the solenoid. With connector off the solenoid, measure the resistance of the solenoid across the two pins. If I recall it should be in the range of 15 - 40 ohms. If the solenoid is OK, check the fuse in the underhood panel. Unlikely, because that fuse also controls several other devices that would set codes. Then with key on, check for 12V on the brown wire in the harness connector. If you have 12V, check the continuity of the gray wire, back to pin A9 on the PCM (PCM supplies a pulse width modulated ground to actuate the solenoid).
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
