Leaky injector?
Old Oct 25, 2004 | 01:42 AM
Demus's Avatar
Leaky injector?
How long should the fuel system hold pressure? I just installed new injectors and noticed that pressure drops in the system, gradually over time. I worked it out to be 6 psi over a period of 20 minutes. Or 0.3psi/minute. Is this normal?
Old Oct 25, 2004 | 03:38 AM
TobyZ28's Avatar
Re: Leaky injector?
Thats not too bad, but not good either. Sounds like the check ball thing that should hold the pressure in the pump is not holding all the pressure. If it gets a lot worse you should replace the pump. A friend of mine had his go bad too, it dropped all pressure within a few seconds ... but he was still able to start the car if he primed it a few times
Old Oct 25, 2004 | 04:11 AM
Lower's Avatar
Re: Leaky injector?
Is this with the car on, or off? I thought pressure drop was only a problem when the car is on, but I'd never considered checking PSI after shutting it down. What's normal?
Old Oct 25, 2004 | 08:08 AM
hawk232's Avatar
Re: Leaky injector?
that sounds about normal, it will leak down over time
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
