Cheapest price TA cover?
Old Jan 2, 2005 | 10:52 PM
jcolez28's Avatar
I recently had a site that offered them for around $120 but lost it. Does anyone know where. Thanks
Old Jan 2, 2005 | 10:59 PM
Fuels94TA's Avatar
Re: Cheapest price TA cover?
Get out ebay sometimes i'll see them for about $100 new.
Old Jan 3, 2005 | 08:22 PM
slp223's Avatar
I would like to let eveyone who is thinking about a TA cover for there 12 bolt some words of advice. Due to me learing the hard way.
1. don not fill the rear end fluid all the way to the fill hole like you would in normal conditions. the fill hole is placed higher then normal to clear the support filling it to the hole will fill the axle tubes with fluid.
2. I have a 21mm sway bar it will not clear the cover. I have to shim the mounts and lower the position of the bar the even get it on the car.
3. my car i lowered so it may not effect all cars but the upper pan hard bar would bang on the cover over bumps in the road. I had to notch the upper bar.
free advice take it for what its worth.
Old Jan 3, 2005 | 11:07 PM
jcolez28's Avatar
slp223 thanks for the advice. Ill look mine over first to check for clearance. I found the cover at New Era for $122. It is a MAC . Is that a good one for the price ? Thanks
Old Jan 4, 2005 | 04:36 AM
Severous01's Avatar
any 9" or moser rear you'll have to notch the PHR or purchase the relocator kit...it's nothing more than a spacer like the LCA brackets. some PHRs like the aluminum ones may be small enough to pass without the brackets...that i dont know.
by the way, it would help to know which rear you're speaking of...10-bolt or 12.
Old Jan 4, 2005 | 09:09 PM
jcolez28's Avatar
10 bolt stock. Thanks
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
capebuf
Jan 13, 2015 07:22 PM
ddr698
Jan 9, 2015 10:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
