cheap and easy power upgrades
Old May 1, 2011 | 06:53 PM
vicki711's Avatar
im buying a stock 95 z28 and wanna upgrade to a little bit more power.. im looking for cheap options. im gonna start with some headers any other suggestions
Old May 1, 2011 | 07:10 PM
henryz28's Avatar
Re: cheap and easy power upgrades
Headers then a cold air intake; ls1 lid swap if one of the best, but it will take some mods to work. Catback exhaust, 1.6 rrs, cam, lifters, valve springs, and a pcm tune. First you need to be sure everything is in good shape so check the plugs, wires, and fuel filter.
Old May 1, 2011 | 07:56 PM
calaban's Avatar
Is it hard to put the ls1 lid setup on the lt1 cars?j. What's involved?
Old May 1, 2011 | 08:03 PM
henryz28's Avatar
I did it on my TA with a ws6 hood in less than 2hrs; it is more difficult on the z28s, ss, and TA's, but it can be done. I believe there is a couple ways to do it; one involves cutting the core support, I don't know if I would do that. I will try to find some links for you. Here is mine, but it will not work without a lt1 ws6 or other aftermarket camaro hoods
Old May 1, 2011 | 08:04 PM
henryz28's Avatar
http://www.ls1tech.com/forums/lt1-lt...lots-pics.html
http://www.ls1tech.com/forums/lt1-lt...maro-hood.html
Old May 1, 2011 | 08:16 PM
calaban's Avatar
I have the harwood cowl induction hood so there's extra clearance in that area anyway.
Old May 1, 2011 | 09:01 PM
henryz28's Avatar
You should be able to do it as I did then; all you have to do is cut some plastic off of the ls1 lower air box, so that it sits and forms nicely to the core support. For the hose from the tb to the MAF I used a rubber 3.5" sewer hose from homedepot. Then just bolt the radiator support/ls1 lower airbox down with self tapping screws. Sorry for hijacking this thread; someone should do a sticky on how to do the lid swap on lt1 cars.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ModdedNerd
Feb 5, 2015 04:37 AM
XtremeLt1
Sep 13, 2002 08:50 PM
