Chassis Mod
Old Jul 15, 2003 | 12:52 PM
  #16
94formulabz's Avatar
Originally posted by raceryan
What's the main difference between Weld in and bolt on Sub-Frame connectors?? I think that you have to relocate stuff with weld ins, and I'm wondering if it's worth the hassle.
I never had bolt ins, but the argument against them is that the bolts stretch enough that they jsut arent' effective. There was nothing to relocate for the BMR install. Unless you have a driveshaft loop or intrusive exhuast you shouldn't have to relocate anything for DD either based on my cousins car which i didn't actually do the install on but have spent my time under.
Old Jul 15, 2003 | 07:59 PM
  #17
Bud M's Avatar
Originally posted by Red96Lt1
Thanks for the info, nice pics by the way. What did you think about your strut tower brace, is it worth it?
I think it's worth it. I like the difference it made in the way the car steers through corners. And it's not a real expensive part.
You also might consider a stiffer front sway bar.
As far as bolt in vs. weld in SFCs I think the drawbacks of bolt in SFCs are mainly at the rear where (I believe) the only attaching point is the LCA pivot bolt. That would not only significantly reduce the effectiveness of the SFC but possibly have negative effects on the rear suspension action. But I would expect that DD type SFCs along with a stiffer tunnel brace would stiffen the floorpan considerably more than the other type.
Old Jul 16, 2003 | 09:06 AM
  #18
raceryan's Avatar
Thanks, the BMR SFC's are my next thing to do. Lucky I have acess to a shop with free lifts and a free welder!
Quickss96
Jan 29, 2016 05:56 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
alliance12364
Sep 23, 2015 12:40 PM
DelSoto
Sep 19, 2015 05:31 AM
CARiD
Jul 7, 2015 08:19 AM
