changing springs with heads on
Old Nov 24, 2003 | 10:36 PM
1FASASZ's Avatar
Question changing springs with heads on
i was just wondering ho you stop the valve from faling into the engine when you take the spring off
Old Nov 24, 2003 | 10:38 PM
You can use an adapter and compressed air or you can bring the piston to TDC and the valve will rest on the top of it after going down a little.
Old Nov 24, 2003 | 10:45 PM
QCKZ28's Avatar
my air compressor failed and i dropped a valve
now i know you cant use a small air brush compressor (30psi)
jesse
Old Nov 24, 2003 | 10:48 PM
96speed's Avatar
Turning the piston to TDC is a win-win technique.
Ryan
Old Jan 4, 2004 | 10:07 PM
1FASASZ's Avatar
wont the valve drop too far if you bring it to tdc
Old Jan 4, 2004 | 10:12 PM
SVT Killer LV's Avatar
if you put each cylinder to tdc and do the intake and exhaust springs for that specific cylinder then theres absolutely NO way for the valve to drop....
Old Jan 4, 2004 | 10:15 PM
jay g's Avatar
another way if you dont have air is to use a piece of nylon rope smaller than your spark plug threads diameter, put the piston at the bottom then push the rope into the plug hole, leave a few inches hang out the plug hole, then bring the piston up and the rope will hold the valves closed, change your springs and just turn the engine back a bit and pull your rope out.
ive done this many times when doing valve seals for someone who doesnt have air at there place
Old Jan 4, 2004 | 10:19 PM
1FASASZ's Avatar
thanks ill try it
Old Jan 4, 2004 | 11:13 PM
Z28ROC's Avatar
Yep.
Why would you do it any other way?
Old Jan 4, 2004 | 11:16 PM
Originally posted by Z28ROC
Yep.
or you can do it my way... take the heads off replace with new ones
Old Jan 4, 2004 | 11:31 PM
neat's Avatar
I've used all three methods; rope, air, and TDC. They all work well.
Old Jan 4, 2004 | 11:35 PM
1loudz's Avatar
i just did mine 2day for the first time with the heads on. lemme tell you, it is a real pain with a screw type valve compressor, but is doable. i brought it to tdc and did it that way. its really no big deal, there is a little room between the piston and the valve, so it does drop down a little, but your valve seal should hold up the valve plenty to get your retainers on. Its MUCH easier, and faster w/ the heads off obviously, but its gonna cost you.
-Ryan
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
95chwagon
Jan 13, 2015 09:19 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
