changing rear end, should driveshaft just pop out of yoke or
Old Apr 1, 2003 | 06:24 PM
D James's Avatar
Is there some c clips or something holding the driveshaft into the yoke of the rear end, or should they just pop out. I'm trying to change the rear end out and the driveshaft seems to be stuck in there, I'm afraid of just yanking real hard on it. I don't have much light under there so its hard to see if something is holding in there
Old Apr 1, 2003 | 06:39 PM
95CamaroZ-28's Avatar
As long as you have taken the braces off that hold the universal joint to the yolk, it should come on out.
Old Apr 1, 2003 | 06:42 PM
D James's Avatar
yep I took those out, looks like I might have to do a little prying and see they come loose.
Old Apr 1, 2003 | 06:52 PM
Z28ROC's Avatar
Push it towards, and into the trans tailshaft. That will give it clearance to drop down.
Old Apr 1, 2003 | 06:53 PM
norcalstreet's Avatar
It fits in their snuggly. After you remove the clips the 95CamaroZ-28 talks about just yank it out.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
FredM
Dec 18, 2014 01:40 PM
