Changing pistons????
hey guys, i heard rumor that you may be able to change pistons from underneath without removing the motor. is this possible with LT1s?
if not, how do you guys do it? pull the motor out the top like usual?
im just thinking about when it comes time to put some forged pistons in.
thanks guys.
thanks guys.
Re: Changing pistons????
Originally Posted by rskrause
It's a lot easier to pull the motor.
Rich
Rich
Originally Posted by ss#1230
out of the top correct? some people have said that it comes out the bottom because the motor sits so far under the dash.
so if your gonna do all the work to get the motor out the bottom, then why not just leave it in the car and pull the crank, rods and pistons out the bottom?
thanks guys.
thanks guys.
You don't have to bore the motor, but if you're buying new pistons anyway, you may as well have the block checked to make sure everything is nice and straight. No sense in putting round pistons into oval holes.
Sergio
Jan 27, 2016 04:27 PM
