Changing out Opti...what do I need?
Old Feb 4, 2004 | 04:45 PM
SlickLT1's Avatar
I will be changing the opti on my car this weekend, and was wondering if I needed to order any seals or gaskets before hand. Is there anything else I will need other than the opti and a new gasket? Thanks for your reply's Cory
Old Feb 4, 2004 | 04:53 PM
Water pump gaskets for sure. You may/may not need o-rings for the water pump drive (#156 in drawing) and opti drive (if vented-you did not post the year of your car).
GM p/n
12553792 water pump o-ring 2 required
10474278 opti o-ring 2 required
10128343 water pump gaskets or Fel Pro#35072
Old Feb 4, 2004 | 04:58 PM
Tires_Smokin's Avatar
lemee see here...
*waterpump gasket
*coolant
*pulley puller - maybe, if it doesnt come off
*bucket to catch the coolant
*rags
*buy new waterpump - unless it's alrready been replaced recently
I think thats about it if I remember correctly. If you need a guide, do a search.
Old Apr 9, 2004 | 12:27 PM
CrAkD X 95TA's Avatar
GM p/n
hey shoebox i went and got the 2 sets of O rings with your part numbers but the guy just gave me 4 o rings didnt know which was which 2 are yellow 2 are blue which gos to which?
Old Apr 9, 2004 | 01:18 PM
95BlackTA's Avatar
Beer.
Trust me, you'll need a few.
Old Apr 9, 2004 | 01:24 PM
Easy to remember-blue ones for the water pump.
Old Apr 9, 2004 | 02:42 PM
MentalCaseOne's Avatar
Blah.... I am confused. If they have part numbers then how come he didnt know what was what??
Marvin
Old Apr 9, 2004 | 02:45 PM
Pasky's Avatar
Originally posted by 95BlackTA
Beer.
Wow, I was all scared the first time I was gonna change the opti. You guys make it seem like a day long project, I had it off in 20 minutes....*shrug* Took about the same amoutn of time to get back on. Screw a puller, i just smacked the hell out of it with a rubber mallet.
Old Apr 11, 2004 | 10:51 PM
apick42's Avatar
I learned this the hard way. Buy a fel pro timming cover gasket set it has every gasket and new seals also and is cheaper.
Old Apr 11, 2004 | 10:56 PM
Marvin
Maybe the parts guy just threw them out there loose and not in any package.
96SilverRam
Nov 20, 2016 11:19 AM
jayblev95
Jun 7, 2015 04:04 PM
mdenz3
May 22, 2015 09:25 AM
May 1, 2015 01:14 PM
NewsBot
Jan 21, 2015 06:10 PM
