Changing coolant in radiator?
Old May 23, 2009 | 07:57 AM
dblj1500's Avatar
I was just wondering, I noticed that my coolant looks a little dirty and would like to just change it out of the radiator for now till i can get to a shop to do the whole system. Is there anything special i have to do or can i just drain it out the bottom and fill the radiator back up? Thanks for the help. Justin
Old May 23, 2009 | 10:15 AM
Hal Fisher's Avatar
Yes, you can do that. Don't just dump the old antifreeze anywhere and don't let animals drink it (cats love the stuff but it will kill them). Afterwards you have to open the two bleed screws on the radiator hoses to both fill the radiator up fast and to bleed the system (put a rag underneath the drain screws). You don't want much coming out the screws.
Hal
Old May 23, 2009 | 10:29 AM
sbs's Avatar
sbs
That would be a waste of time and antifreeze. Either change the coolant or have it changed. Doing it halfway and then having it done again is
Old May 23, 2009 | 11:50 AM
All you need to do is pull the block drain plugs (one is the knock sensor) when you drain the radiator, and you can drain the entire system. When refilling, follow Shoebox's guidelines, or you will have problems with air in the system and overheating:
http://shbox.com/1/4th_gen_tech2.html#radflush
Old May 23, 2009 | 12:24 PM
dblj1500's Avatar
K, Thanks for the info. It looks like I will just attempt to do this myself.
Old May 23, 2009 | 02:15 PM
SS44Camaro's Avatar
shbox site shoes step by step how to do it
calaban
May 18, 2020 06:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
warmeck
Apr 16, 2015 05:53 PM
captcorvette
Mar 7, 2015 12:37 PM
MattFick
Feb 15, 2015 10:16 PM
