Changing cam
Old Sep 24, 2008 | 03:52 AM
MrCamu's Avatar
Changing cam
I'm changing my cam from cca-07-502-8 to cca-07-467-8, how much hp gain I would expect?
Old Sep 24, 2008 | 07:59 AM
NightTrain66's Avatar
My guess would be about 5-10 HP from 4500-6200 RPM.
I would spend the $$$ towards upgrading to some 1 3/4 LT headers or Yank/Vigilante 3000/3200 stall before you spent the $$$ on that cam. It looks bigger in afew areas but will not act much different than what you have until 4500 RPM or so and even then, the difference is not drastic.
Make sure you ahve some good springs if you go with the XFI cam also.
Lloyd
Old Sep 24, 2008 | 09:27 AM
MrCamu's Avatar
Ok, so if change from shorty headers to longtubes the hp gain would be bigger than changing cam...
I have crane 99846-16 springs, they can easily handle .600" lift.
Old Sep 24, 2008 | 10:45 AM
BUBBA's Avatar
373s
Old Sep 24, 2008 | 11:57 AM
MrCamu's Avatar
Originally Posted by BUBBA
373s
hä??
Old Sep 24, 2008 | 12:15 PM
6SpdLT1Z's Avatar
about the same... 5-10rwhp
Old Sep 24, 2008 | 12:37 PM
bombebomb's Avatar
hä??
3.73's. HIs post could not be much more vague, I think hes hinting at you to get a set of gears.
Old Sep 24, 2008 | 01:20 PM
slomarao's Avatar
3600 stall, 3.73 gears. Than when you have the time and money pick up LT's and run a true dual setup. Than you will be looking at some good gains.
Old Sep 24, 2008 | 02:53 PM
BUBBA's Avatar
> -:- ( vaguer?)
Old Sep 25, 2008 | 01:06 PM
MrCamu's Avatar
I think I'll order LT's and the cam...
Old Sep 27, 2008 | 05:43 AM
yep, 1 3/4 LT headers would get you 10-15 HP over what you have and show more gain than the cam swap.
Just make sure you have good springs for that XFI cam.
Lloyd
IgorT.455/406
Mar 12, 2015 03:39 AM
armedtrigger
Feb 24, 2015 08:30 PM
blac94Z
Feb 18, 2015 11:36 AM
birdblack
Dec 30, 2014 06:59 PM
