changing from 52mm-58mm throttle body ?
Old Jan 1, 2005 | 06:40 PM
  #16
Boosted_Z28's Avatar
Re: changing from 52mm-58mm throttle body ?
I would have to agree that any type of "forced induction" is in a sense compressing the air going into the motor, hence the pressure reading on the boost gauge, but it is the engines inability to "swallow" that air that causes the pressure to be there in the first place
Old Jan 1, 2005 | 06:47 PM
  #17
NOMAD's Avatar
Maybe i'm just over ****, but I think you would be 100% correct if it read "any type of "forced induction" is in a sense compressing the air into the motor" I view compressing the air as compressing it, then injecting it into the engine since you stated "going into the motor" which in turn would mean it has not entered the engine yet So maybe we are saying the same thing
And you are correct on the inability to swallow the air
-Shannon
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
David Dorris
Jan 17, 2015 08:10 PM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
